  3. how to use "insertXMlMenu" in capture
  • Subscribers 166
  • Views 2937
robin chu
robin chu over 13 years ago
 There is a "insertXMLMenu"  function in capture's tcl demo as follow:
InsertXMLMenu [list [list "TopLevelMenu"] "" "" [list "popup" "&TopLevelMenu" "0"]]
InsertXMLMenu [list [list "TopLevelMenu" "SubMenu" ] "" "" [list "action" "&SubMenu..." "0" "SubMenuActionLabel" "MenuUpdateLabel"]]
 I don't know how to fill in the parameters.
Is there I can find a document that explain these functions?
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    Sample menu below, you need to register the function
    InsertXMLMenu [list [list "NordcadMenu"] "" "" [list "popup" "&Nordcad" "0"]]
    InsertXMLMenu [list [list "NordcadMenu" "SampleAlwaysEnabled1" ] "" "" [list "action" "&Intelligent PDF..." "0" "sampleEnabledAction1" "sampleEnabledUpdate1"]]
    proc disableMenuUpdate {} {
    return false
    proc enableMenuAction1 {} {
    set lMessage "Creating PDF"
    set lMessageStr [DboTclHelper_sMakeCString $lMessage]
    DboState_WriteToSessionLog $lMessageStr
    MenuCommand "65004"
    return true
    proc enableMenuUpdate {} {
     return true
    RegisterAction "sampleEnabledUpdate1" "capTrue" "" "enableMenuUpdate" ""
    RegisterAction "sampleDisabledUpdate" "capTrue" "" "disableMenuUpdate" ""
    RegisterAction "sampleEnabledAction1" "capTrue" "" "enableMenuAction1" ""
    documentation is found in %cdsroot%\tools\capture\tclscripts\OrCAD_Capture_TclTk_Extensions.pdf
    samples are found in the same directory
    Best regards
    Ole
  • PEscher
    PEscher over 13 years ago
    Hi Ole, do you know if it is possible to also add such kind of menu directly into the PM tree? When we use the registerAction with 'PM' at the end it will always show up in the "more..." section, but we want our commands and menus directly at the top Thanks Patrick
  • tennywhy
    tennywhy over 8 years ago in reply to Ejlersen
    could you give me some more explain about  "InsertXMLMenu" ?  i cant understand the args about it
