  3. ERROR WHILE CONVERTING ORCAD TO ALLEGRO
  • Views 16228
KARPCB
KARPCB over 13 years ago
Hi ,
I got below errors and warning  while converting orcad to allegro.,
WARNING (Layout To Allegro PCB Design), Empty mechanical pins were discarded from footprint '16QSOPLL_6'
WARNING (Layout To Allegro PCB Design), Netname 'DEFAULT' was discarded because it is not used by any component pad
ERROR (Layout To Allegro PCB Design), Error while writing the PCB Editor Database.
ERROR: Subclass name ALL not valid Allegro subcls for class ETCH. Quitting.
ERROR: loading Allegro database
How to clear those errors? in which version hotfix used to solve this problems?
Thankyou.,
Karthik.
  • oldmouldy
    oldmouldy over 13 years ago
    It sounds like you have a Routing Layer named ALL, in which case, either change the name of the layer to Top, or Bottom, or some other layer name, or change the layer type from Routing to, say, Documentation.
  • KARPCB
    Thank you very much for your Reply.,now i am understand whats the problem.,
  • ElectroIndia
    ElectroIndia over 6 years ago in reply to oldmouldy
    I am facing same problem, but where do I need to change the layer named "ALL" to "Top" or "Bottom" ?
  • ElectroIndia
    ElectroIndia over 6 years ago in reply to KARPCB
    How you changed All to Top or Bottom?
