  3. Refdes Attribute ?
  • Views 15425
Refdes Attribute ?
luanvn81
luanvn81 over 13 years ago
 Hi !
I want to get some atrtibute of refdes, such as rotation, xy, textBlock , isMirrored ( ex: refdes-> rotation), but i don't find any  function to do that. there is only  Text Attribute. How can i do it? Please help me?
Tks.
Luan.
  • oldmouldy
    oldmouldy over 13 years ago
    Try axlDBGetAttachedText documented in algroskill.pdf in the doc\algroskill directory of the installation, this takes the dbid of an object and returns a list of dbids that are the attached Text Attributes, these Text Attributes will have the modifier properties attached.
  • luanvn81
     Hi oldmouldy! Sorry for reply too late.
     Thank for your advice , I have tested with function  axlDBGetAttachedText and the result is OK. Here's my test code:
    foreach(sym_chk, allsymlist
    attach_text_list = axlDBGetAttachedText(sym_chk)
        foreach( item attach_text_list
            if(item->layer == "REF DES/SILKSCREEN_TOP" || item->layer == "REF DES/SILKSCREEN_BOTTOM" then
            sym_chk_refdes_text = item->text
            sym_chk_refdes_layer = item->layer
            sym_chk_refdes_justify = item->justify
            sym_chk_refdes_txtbock = item->textBlock
            sym_chk_refdes_mirror = item->isMirrored
            sym_chk_refdes_rotation = item->rotation
            );end if
        );end foreach
    );end foreach
    Tks.
    Luan.
