  3. Modify film_reorder.il
  • Replies 9
  • Subscribers 168
  • Views 20070
bulldog
bulldog over 13 years ago
I have been looking at the program "film_reorder.il" (available at cadence.com) and have found it useful but would like to make a small modification to it.  After you have selected a layer to be moved (up or down) in the list you have to re-select it if you want to move it more than one position.  Does anyone know of a way to modify this program so the selected layer stays selected until another layer is selected?  I would like to just click the up/down arrow X times until it is moved into the correct position without having to keep re-selecting the layer.
Thanks!
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    That is possible. You'll have to save all current visibility settings - the easiest thing would probably be to create a script that saves a temp colorview file to disk. When you close the program this color view should be reselected and then the temp file deleted.
     Similarly selecting a film could load the corresponding film.
    (defun _ns_save_org_colorview ()
    let((tmp_file)
     ;------------------- save the original color view for later restoration
     tmp_file = axlDMOpenFile("ALLEGRO_SCRIPT", "tmp", "w")
     fprintf(tmp_file "scriptmode +i +n +w +c\n")
     fprintf(tmp_file "setwindow pcb\n")
     fprintf(tmp_file "colorview create\n")
     fprintf(tmp_file "setwindow form.colorview_create\n")
     fprintf(tmp_file "FORM colorview_create colorview_name ns_pdf_out\n")
     fprintf(tmp_file "FORM colorview_create save\n")
     fprintf(tmp_file "FORM colorview_create done\n")
     axlDMClose(tmp_file)
     axlShell("replay tmp")
     if( isFile( "tmp.scr") then deleteFile("tmp.scr"))
    (defun _ns_load_view (f2view)
    let((tmp_file)
     ; load the original color view
     fprintf(tmp_file "setwindow form.vf_vis\n")
     fprintf(tmp_file "FORM vf_vis colorview_list %s\n" f2view)
    Best regards
    Ole
  • seyerfred
    seyerfred over 13 years ago
    Hi
    the code is for colorview create function, for what i mean loading the artwork film in the list and  when select from list window
    it will display the desired artwork.
    Thank you...
  • Johnny Lam
    Johnny Lam over 10 years ago
    Hi Ole,
         I like this film_reorder skill file, But when I insert code. did not work for me. Please help.
    ("UP"
    for(key 0 film_count-1
    film_order[key] = nth(key val)
    ); end for unless
    (setq count -1) (setq j -1)
    (prev_list = final_list = next_list = nil)
    (setq sel_index 0 )
    sel_items = axlFormListGetSelItems(myform "FILMS_LIST")
    unless(length(sel_items) != 1
    foreach(items val
    j++
    unless(items != car(sel_items)
    sel_index = j
    ) ; end unless
    ) ; end foreach
    (setq haha film_order[sel_index])
    if(sel_index != 0 then
    current_prev = film_order[sel_index-1]
    else (setq current_prev nil) final_list = val); end if
    unless(current_prev == nil
    for(key 0 sel_index-2
    prev_list = append(prev_list list(film_order[key]))
    ); end for
    for(key sel_index+1 length(brd_films)-1
    next_list = append(next_list list(film_order[key]))
    ) ; end for
    unless(sel_index-2 == -1
    final_list = append(prev_list final_list)
    ) ; end unless
    final_list = append(final_list list(haha))
    final_list = append(final_list list(current_prev))
    unless((sel_index+1 > length(brd_films)-1)
    final_list = append(final_list next_list)
    ) ; end unless
    ) ; end unless
    ) ; end if
    axlFormListDeleteItem(myform, "FILMS_LIST" val)
    if(final_list == nil then (setq final_list val))
    axlFormListAddItem(myform, "FILMS_LIST" final_list 0)
    (setq val final_list)
    if(sel_index > 0 then
    axlFormListSelect(myform "FILMS_LIST" sel_index-1)
    else
    axlFormListSelect(myform "FILMS_LIST" 0)
    ("DOWN"
  • EvanShultz
    EvanShultz over 10 years ago
    Hi Johnny,
    I copied Ole's solution and it works for me in 16.6 and 17.2. I don't see how to attach a random file here but I tried making it a media file. May not work. If you contact me at evan.shultz@qsc.com I'll send it to you.
    Cheers!
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/film_5F00_reorder.zip
