  3. Modify film_reorder.il
  • Replies 9
  • Subscribers 168
  • Views 20069
bulldog
bulldog over 13 years ago
I have been looking at the program "film_reorder.il" (available at cadence.com) and have found it useful but would like to make a small modification to it.  After you have selected a layer to be moved (up or down) in the list you have to re-select it if you want to move it more than one position.  Does anyone know of a way to modify this program so the selected layer stays selected until another layer is selected?  I would like to just click the up/down arrow X times until it is moved into the correct position without having to keep re-selecting the layer.
Thanks!
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    Without knowing the program and the code behind it my suggestion would be that you look at the action for up/down arrow.
    First point would be to store the value/name of the selected film in the list
    Then as the last command make sure that this value/name is selected in the list just before leaving the up/down arrow action.
    Or you could provide a direct link to the code and I'll see if I can be of more specific help to your question.
    Best regards
    Ole
  • bulldog
    Hi Ole,
    Below is a copy of the program; film_reorder.il
    I looked at the sections UP and DOWN but have no idea how to retain the selected layer.
    Any help you can give me will be greatly appreciated!
    #                      Command: film_reorder                                   #
    #                   Skill File: film_reorder.il                                #
    #                  How To Load: Command> skill load("film_reorder.il")         #
    #               How To Execute: Command> film_reorder                          #
    #               Sourcelink Solution Reference : 11297786                       #
    #                       Author: Jatin Sasan , Cadence Design Systems           #
    #                        Email: jsasan@cadence.com                             #
    #                Creation Date: 09/12/2006                                     #
    #  DISCLAIMER:        #
    # THIS CODE IS UNSUPPORTED AND HAS HAD MINIMAL TESTING.                        #
    # The following code is provided for Cadence customers                         #
    # to use at their own risk. The code may require modification to               #
    # satisfy the requirements of any user. The code and any                       #
    # modifications to the code may not be compatible with current or              #
    # future versions of Cadence products.                                         #
    # THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING               #
    # WITHOUT LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES              #
    # OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.                          #
    #  09/12/2006:  Pops a UI where you can load films and reorder them through    #
    #               Up and Down buttons
    #  Revision history:                                                           #
    #	1.0 Original file		                           Sept 12,2006          #
    #     1.1 Fixed Mirror and Shape fill bug. Options were
    #         getting set incorrectly in reverse order       Dec 17, 2006          #
    #  Advantages:        #
    # a) Easy to Reorder films.
    # b) Preserves the artwork film layer settings                                 #
    #  Limitations:        #
    # a) Artwork film layer settings for undefined line width, Shape Bounding      #
    #    box and XY offset are not preserved. They are reset to default on         #
    #    reordering.                                                               #
    axlCmdRegister("film_reorder" 'film_reorder)
    declare(film_array[50])
    declare(film_order[50])
    (setq brd_films nil)
    unless(axlGetVariable("film_nosort")  ;Allegro by default sorts the film records in Artwork control form
      axlSetVariable("film_nosort" t)       ;Setting this env variable turns off the default sorting.
           ) ; end unless
    procedure( film_reorder()
      _makeForm_artwork_reorder()
       axlFormDisplay(_Form_artwork)
    ); end procedure
    ;#                FORM CREATION                            #
    (defun _makeForm_artwork_reorder ()
       _Form_artwork=outfile("./form_artwork.form" "w")
       fprintf(_Form_artwork "FILE_TYPE=FORM_DEFN VERSION=2\n")
       fprintf(_Form_artwork "FORM\n")
       fprintf(_Form_artwork "FIXED\n")
       fprintf(_Form_artwork "PORT 55 18\n")
       fprintf(_Form_artwork "HEADER \"Artwork Film Re-ordering\" \n")
       fprintf(_Form_artwork "TILE\n")
       fprintf(_Form_artwork "TEXT \"Existing Films in Brd:\"\n")
       fprintf(_Form_artwork "TLOC 4 2\n")
       fprintf(_Form_artwork "ENDTEXT\n")
       fprintf(_Form_artwork "FIELD FILMS_LIST\n")
       fprintf(_Form_artwork "FLOC  20 2\n")
       fprintf(_Form_artwork "LIST \"\" 20 7\n")
       fprintf(_Form_artwork "OPTIONS multiselect\n")
       fprintf(_Form_artwork "ENDFIELD\n")
       fprintf(_Form_artwork "FIELD LOAD\n")
       fprintf(_Form_artwork "FLOC 4 6\n")
       fprintf(_Form_artwork "MENUBUTTON \"Load Films\" 12 3\n")
       fprintf(_Form_artwork "FIELD UP\n")
       fprintf(_Form_artwork "FLOC 45 2 \n")
       fprintf(_Form_artwork "MENUBUTTON \"Up\" 6 3\n")
       fprintf(_Form_artwork "FIELD DOWN\n")
       fprintf(_Form_artwork "FLOC 45 6\n")
       fprintf(_Form_artwork "MENUBUTTON \"Down\" 6 3\n")
       fprintf(_Form_artwork "FIELD DONE\n")
       fprintf(_Form_artwork "FLOC 10 16 \n")
       fprintf(_Form_artwork "MENUBUTTON \"Re-order\" 12 3\n")
       fprintf(_Form_artwork "FIELD CANCEL\n")
       fprintf(_Form_artwork "FLOC 35 16\n")
       fprintf(_Form_artwork "MENUBUTTON \"Close\" 12 3\n")
       fprintf(_Form_artwork "ENDTILE\n")
       fprintf(_Form_artwork "ENDFORM\n")
       close(_Form_artwork)
       _Form_artwork = axlFormCreate( (gensym) "form_artwork.form" '(e inner) 'artwork_callback t)
    ); end defun _makeForm_artwork_reorder
    procedure(artwork_callback(myform)
        let( (prev_list final_list )
            case( myform->curField
                    ("FILMS_LIST"
                       /* Nothing to do */
                    ("LOAD"
                           axlFormListDeleteItem(myform, "FILMS_LIST" brd_films)
                           film_count = get_film_list()
                           for(key 0 film_count-1
                               brd_films = append(brd_films list(film_array[key]->film_name))
                           axlFormListAddItem(myform, "FILMS_LIST" brd_films 0)
                           val = brd_films
                    ("UP"
                                film_order[key] = nth(key val)
                                ); end for unless
                             (setq count -1) (setq j -1)
                             (prev_list = final_list = next_list = nil)
                             (setq sel_index 0 )
                             sel_items =  axlFormListGetSelItems(myform "FILMS_LIST")
                             unless(length(sel_items) != 1
                                foreach(items val
                                    j++
                                    unless(items != car(sel_items)
                                         sel_index = j
                                          ) ; end unless
                                       ) ; end foreach
                                (setq haha film_order[sel_index])
                                if(sel_index != 0 then
                                   current_prev = film_order[sel_index-1]
                                 else (setq current_prev nil) final_list = val); end if
                                 unless(current_prev == nil
                                     for(key 0 sel_index-2
                                        prev_list = append(prev_list list(film_order[key]))
                                         ); end for
                                     for(key sel_index+1 length(brd_films)-1
                                        next_list = append(next_list list(film_order[key]))
                                        ) ; end for
                                        unless(sel_index-2 == -1
                                        final_list = append(prev_list final_list)
                                               ) ; end unless
                                        final_list = append(final_list list(haha))
                                        final_list = append(final_list list(current_prev))
                                        unless((sel_index+1 > length(brd_films)-1)
                                         final_list = append(final_list next_list)
                                               ) ; end unless
                                      ) ; end unless
                               ) ; end if
                           axlFormListDeleteItem(myform, "FILMS_LIST" val)
                           if(final_list == nil then (setq final_list val))
                           axlFormListAddItem(myform, "FILMS_LIST" final_list 0)
                           (setq val final_list)
                    ("DOWN"
                                ); end for unless
                             (setq countd -1) (setq jd -1) (prev_listd = final_listd = next_listd = nil)
                             (setq sel_indexd 0)
                             sel_itemsd =  axlFormListGetSelItems(myform "FILMS_LIST")
                             unless(length(sel_itemsd) != 1
                                foreach(items val
                                    jd++
                                    unless(items != car(sel_itemsd)
                                         (setq sel_indexd jd)
                                          ) ; end unless
                                       ) ; end foreach
                                 hahad   = film_order[sel_indexd]
                                if((sel_indexd != length(brd_films)-1) then
                                   current_prevd = film_order[sel_indexd+1]
                                 else (setq current_prevd nil) final_listd = val); end if
                                 unless(current_prevd == nil
                                     for(key 0 sel_indexd-1
                                        prev_listd = append(prev_listd list(film_order[key]))
                                         ); end for
                                     for(key sel_indexd+2 length(brd_films)-1
                                        next_listd = append(next_listd list(film_order[key]))
                                        ) ; end for
                                        unless(sel_indexd == 0
                                        final_listd = append(prev_listd final_listd)
                                               ) ; end unless
                                        final_listd = append(final_listd list(current_prevd))
                                        final_listd = append(final_listd list(hahad))
                                        unless((sel_indexd+2 > length(brd_films)-1)
                                         final_listd = append(final_listd next_listd)
                                               ) ; end unless
                                      ) ; end unless
                               ) ; end if
                           if(final_listd == nil then final_listd = val)
                           axlFormListAddItem(myform, "FILMS_LIST" final_listd 0)
                           (setq val final_listd)
                    ("DONE"
                           (setq count 0) (setq reverse_film nil)
                           design_value = cadr(axlDBGetDesignUnits())
                           case(design_value
                               (0 bBox = 254)(1 bBox = 254)(2 bBox = 254) (3 bBox = 2540)(4 bBox = 25400)
                               ) ; end case
                           dbid_film = axlGetParam("artwork")
                           foreach(filmgp dbid_film->groupMembers
                              test_film = strcat("artwork:" filmgp)
                              _film = axlGetParam(test_film)
                               unless(filmgp == nth(0 val)
                                axlDeleteObject(_film)
                                      ) ; end unless
                                  ) ; end foreach
                             add_film = remove(nth(0 val) val)
                             foreach(films add_film
                                reverse_film = append(reverse_film list(films))
                                     ) ; end foreach
                             foreach(new_film reverse_film
                                 for(jt 0 length(brd_films)-1
                                   unless(new_film != film_array[jt]->film_name
                                        axlfcreate(new_film list(film_array[jt]->rotation
        00 00 00 bBox
        film_array[jt]->negative
        film_array[jt]->mirror
        film_array[jt]->fullcontact
        film_array[jt]->unconnect_pads
        film_array[jt]->pad_aperture
        film_array[jt]->aperture_rotation
        film_array[jt]->shapefill
        film_array[jt]->vector) car(film_array[jt]->film_layers))
                                         ); end unless
                                     ) ; end for
                                   ); end foreach
                        sprintf(msg_test,"Films reordered successfully. Open Artwork control form to verify the reordering\n")
                        axlUIConfirm(msg_test)
                     ("CANCEL"
                        axlFormClose(myform)
                        axlCancelEnterFun()
                        axlTempFileRemove("form_artwork.form")
                 ) ; end case
         ); end let
    ); end procedure
    ;#                Main Program get_film_list               #
    (defun get_film_list ()
           prog( (dbid_film test_film _film _active_films tfilm)
          defstruct(filmrecord film_name film_layers pad_aperture fullcontact mirror negative rotation
                               shapefill unconnect_pads aperture_rotation vector)
          (setq i 0)
                  film_array[i] = make_filmrecord(
                                                  ?film_name           _film->name
                                                  ?film_layers         list(_film->groupMembers)
                                                  ?pad_aperture        _film->drawMissingPadApertures
                                                  ?fullcontact         _film->fullContact
                                                  ?mirror              _film->mirrored
                                                  ?negative            _film->negative
                                                  ?rotation            _film->rotation
                                                  ?shapefill           _film->suppressShapeFill
                                                  ?unconnect_pads      _film->suppressUnconnectPads
                                                  ?aperture_rotation   _film->useApertureRotation
                                                  ?vector              _film->vectorBasedPad
                ; Modify the structures to have 0 or 1 so as to pass argument during film creation.
                if(film_array[i]->pad_aperture == t then film_array[i]->pad_aperture=1 else film_array[i]->pad_aperture=0)
                if(film_array[i]->fullcontact == t then film_array[i]->fullcontact=1 else film_array[i]->fullcontact=0)
                if(film_array[i]->mirror == t then film_array[i]->mirror=1 else film_array[i]->mirror=0)
                if(film_array[i]->negative == t then film_array[i]->negative=0 else film_array[i]->negative=1)
                if(film_array[i]->shapefill == t then film_array[i]->shapefill=0 else film_array[i]->shapefill=1)
                if(film_array[i]->vector == t then film_array[i]->vector=1 else film_array[i]->vector=0)
                if(film_array[i]->unconnect_pads == t then film_array[i]->unconnect_pads=1
                else film_array[i]->unconnect_pads=0)
                if(film_array[i]->aperture_rotation == t then film_array[i]->aperture_rotation=1
                else film_array[i]->aperture_rotation=0)
                case(film_array[i]->rotation
                     (0   film_array[i]->rotation=0)
                     (90  film_array[i]->rotation=2)
                     (180 film_array[i]->rotation=4)
                     (270 film_array[i]->rotation=6)
                    ) ; end case
                    i++
                       ) ; end foreach
             return(i)
                  ) ; end prog
       );end defun
  • Ejlersen
    Hi
    At the bottom of the code for UP (line 182) you can insert code like
    if(sel_index > 0 then
      axlFormListSelect(myform "FILMS_LIST" sel_index-1)
    else
      axlFormListSelect(myform "FILMS_LIST" 0)
    The film list works by indexes or names, the command axlFormListSelect should be able  to take both a list of arguments and index as the argument. Could not get it working by passing "sel_items" which is why it ended up with indexes
    you need to do something similar for the Down code.
    Best regards
    Ole
  • bulldog
    Hi Ole,
    That worked perfectly!  Many thanks for your help and more importantly I learned something new.
  • seyerfred
    seyerfred over 13 years ago
    hi Ole,
    this code is very good. and i want to modify this that if you select the film will display the visibility, is it possible?
    Thank you..
