  3. Help setting the rotation Angle for dynamic buffer.
  • Views 14547
Vince V
Vince V over 13 years ago
Doing some simple move dynamics and would like to rotate the objects and would like to set the angle increment to 5 degrees. I'm using the command  (axlSetRotateIncrement ?angular 5) and it does not appear to be working. Any help would be appreciated.
Vince
  • aCraig
    aCraig over 13 years ago
    I haven't used axlSetRotateIncrement, so maybe someone else can explain how to get it to  work. For dynamic rotation I do the following:
      (setq cursor (axlCursorGet nil))
      (setq angle (axlEnterAngle cursor ?lockAngle 90))
      (setq angle (axlSetDynamicsRotation angle))
    You would set lockAngle to 5.
    Craig
