  3. Example Skill Tutorial
  • Subscribers 166
  • Views 22445
JuergenWeber
JuergenWeber over 13 years ago
Hi
i have found following code on www.referencedesigner.com/.../allegro_skill_76.php
Is it possible to read the les4.form from the advanceform.il file?
Thanks for your help
Jürgen
axlCmdRegister( "advanceform" `advanceform)
procedure( advanceform()
	les4_form = axlFormCreate( (gensym) "les4.form" nil 'les4_form_Action t)
	axlFormDisplay(les4_form)
); end of procedure
procedure( les4_form_Action(les4_form)
	case( les4_form->curField
		("Close_button"
        	axlFormClose( les4_form )
		 	axlCancelEnterFun( )
 		("Run_button"
			les4_form_run()
	); end case
); end of procedure
procedure( les4_form_run()
	; Create output file to write report
	cl_file = outfile("check_list.rpt" "w")
		; ------ Print Header
		fprintf(cl_file "**********************\n")
		fprintf(cl_file " Check List Report\n")
		fprintf(cl_file "**********************\n\n")
		axlUIWPrint(les4_form getCurrentTime())
		; ------  Print CurrentTime
		fprintf(cl_file "CurrentTime : %s \n" getCurrentTime())
		; ------  Print Designer Name
		fprintf(cl_file "PCB Designer Name : %s \n" axlFormGetField( les4_form "name"))
		; ------  Print Design Name
		fprintf(cl_file "Design Name : %s \n" axlCurrentDesign())
		; ------ Print value of check box
		if( axlFormGetField(les4_form "check1") then check = "YES" else check = "NO" ); end if
		fprintf(cl_file "Do you check DRC? : %s \n" check)
		; ------ Print	value of popup
		fprintf(cl_file "Exist SMD in this project : %s \n" axlFormGetField( les4_form "pop1"))
		; ------ Print	value of slidebar
		fprintf(cl_file "Layers number : %d \n" axlFormGetField( les4_form "slidebar1"))
		; ------ Print value of group
		if( axlFormGetField(les4_form "both") then
			silk_side = "Both"
		else
			if( axlFormGetField(les4_form "top") then silk_side = "Top" else silk_side = "Bottom" ); end if
		); end if
		fprintf(cl_file "Silk exist on : %s \n" silk_side)
	close(cl_file)
); end of procedure
Now creat another file called les4.form with the following content
 FILE_TYPE=FORM_DEFN VERSION=2
FORM
FIXED
PORT 40 40
HEADER "Check List Report"
#=== must define popup before using
POPUP "Yes" "Yes" , "No" "No" .
TILE
#========== using STRFILLIN
TEXT "PCB Designer Name"
FLOC 1 1
ENDTEXT
FIELD name
FLOC 20 1
STRFILLIN 15 20
ENDFIELD
#========== using CHECKLIST
TEXT "Do you checked  DRC?"
FLOC 1 5
ENDTEXT
FIELD check1
FLOC 20 5
CHECKLIST "Yes"
ENDFIELD
#========== using POPUP
TEXT "Exist SMD in this project"
FLOC 1 10
ENDTEXT
FIELD pop1
FLOC 20 10
ENUMSET 6
POP "pop1"
ENDFIELD
#========== using INTSLIDEBAR
TEXT "Layers number"
FLOC 1 15
ENDTEXT
FIELD slidebar1
FLOC 20 15
INTSLIDEBAR 2 2
MIN 2
MAX 30
ENDFIELD
#========== using GROUP
TEXT "Silk exist on"
FLOC 1 20
ENDTEXT
GROUP ""
GLOC 18 18
GSIZE 22 5
ENDGROUP
FIELD top
FLOC 19 20
CHECKLIST"Top" "grp"
ENDFIELD
FIELD bottom
FLOC 25 20
CHECKLIST "Bottom" "grp"
ENDFIELD
FIELD both
FLOC 33 20
CHECKLIST "Both" "grp"
ENDFIELD
#========== using MENUBUTTON
FIELD Run_button
FLOC 2 27
MENUBUTTON "Run" 7 3
ENDFIELD
FIELD Close_button
FLOC 11 27
MENUBUTTON "Close" 7 3
ENDFIELD
ENDTILE
ENDFORM
  • DE202408202727
    DE202408202727 over 13 years ago
    Hi Jurgen,
    I'm not sure I understand the question. You can use the enclosed text to create the form file using a simple copy and paste.
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
     If you're looking at making the form file generation part of the program, then you could do so
    (defun _mycreateform ()
    let((form_file myform)
    drain()
    form_file = "./les4.form"
    myform = outfile(form_file "w")
    In here you would have to put fprintf statements to print the above into the form file
     example for first line
    fprintf(myform "FILE_TYPE=FORM_DEFN VERSION=2\n")
    Best regards
    Ole
  • joma
    joma over 13 years ago
    Hi Jürgen,
     I don't know if you have found it already but there is an example skill form file at
    ...\share\pcb\examples\skill\form\basic\axlform.il
    The last part of this shows how to embed a form file within a skill file. I have not tried to use it yet so I
    can not give any feedback on how it works though.
    Jim O'Mahony
  • JuergenWeber
    Hi all,
    after my vacation i have found the example and the script for a little readme.doc works now.
    This is not perfect but a little beginning for me.
    One question I have. How can I embed an image file (bitmap) . How can I embed an image file
    Thank for your advice.
    Form
  • DE202408202727
    See the documentation for axlGRPDrwBitmap
