  3. Shape Outside Segment
  • Views 15826
eDaJun
eDaJun over 13 years ago
Dear All,
Can anyone help me how to get the outside segment of a shape...
Inside segment will be disregard. Thanks
image 2
  • DE202408202727
    DE202408202727 over 13 years ago
    There is a quick and nasty way that might work for you:
    Use axlPolyExpand, with an expandValue slightly bigger then the "void" entry width, to expand the shape.
    Use axlPolyExpand with the same value, but negative, to shink the shape again. The outline of the resultant polygon will now be what you want - although you will need to check what happens to corners.
  • eDaJun
    Dear eDave,
    Thanks for the quick response. The problem with poly expand is the corner of the shape is not ate same as before when you negate the expanded shape.
  • DE202408202727
    You could shrink your new polygon slightly more then re-write the original polygon excluding any vertices that fall inside the smaller polygon.
