  3. How to get a layer selected a PIN?
  • Views 16191
myhan
myhan over 13 years ago
 Hi expert,
 I want to know a way to get a layer where I select any pin in.
If a pin is through type and I select the pin at internal layer named Layer2, I want to get ths Layer2.
and If I select the pin at layer named Layer3, I want to get Layer3.
How to do get this?
Thansk in advance.
  • DE202408202727
    DE202408202727 over 13 years ago
    A  pin is an object that doesn't have a layer as such. You are talking about pads. However you can't "select" a pad. The only way I can think to detect the layer that you used to select the pin is to look at the visibility of the etch layers when the selection was made.
  • myhan
    Thansk Dave,
    You are correct exactly.
    But It is difficult to detect the layer if the visibility of serveral layers are ON.
     For example)
        There are 4 layers, TOP, Layer2, Layer3 and Bottom. and the visibility for Layer2 and Layer3 are ON.
              and then I selected Pin on Layer3.
       In this case, I just want to know a pad in Layer3, but it is difficult now.
    Do you know other way to get the layer?
  • DE202408202727
    The command axlPadOnLayer should do the job if you are on 16.6.  Otherwise you will need to use axlDBGetPad and do some analysis.
  • myhan
    Thanks Dave.
