  3. Problems with Tutorial
  • Views 17951
budnoel
budnoel over 13 years ago
I have been attempting to learn SKILL by following a tutorial I found at referencedesigner.com   I've copied the instructions from the tutorial below and when I attempt to run the command I get the following message:  Command > formbutton
E- *Error* axlFormDisplay: argument #1 should be any user-defined (other) type (type template = "o") - nil   Can anyone explain what might be wrong?  Thanks in advance.
SKILL code tutorial begins here :
Allegro SKILL Tutorial | Forms
Copy the following code in a file form.il and save it in the directory C:/cadence/setup/skill (or the directory that allegro.ilinit points to).
axlCmdRegister( "formbutton" `formbutton)
procedure( formbutton()
	les1_form = axlFormCreate( (gensym) "les1.form" nil 'les1_form_Action t)
	axlFormDisplay(les1_form)
); end of procedure
procedure( les1_form_Action(les1_form)
	case( les1_form->curField
		("Close_button"
        	axlFormClose( les1_form )
		 	axlCancelEnterFun( )
 		("Run_button"
			if( axlFormGetField( les1_form "report") then
				axlUIConfirm( "Report value is t (True) ")
			else
				axlUIConfirm( "Report value is nil (False) ")
			); end if
	); end case
); end of procedure
What does this skill code do
There are four axl statements for the form
axlFormCreate - Creates a Form
axlFormDisplay - to Display the form
axlFormClose - to Close the form
axlFormGetField - retrieve the elements in the form
Other code should be easy to follown.
Now creat another file called les1.form with the following content
FILE_TYPE=FORM_DEFN VERSION=2
FORM
FIXED
PORT 25 20
HEADER "Referencedesigner.com"
TILE
FIELD report
FLOC 2 2
CHECKLIST "Create report"
ENDFIELD
FIELD Run_button
FLOC 2 17
MENUBUTTON "Run" 7 3
ENDFIELD
FIELD Close_button
FLOC 11 17
MENUBUTTON "Close" 7 3
ENDFIELD
ENDTILE
ENDFORM
Save the file in the same directory as you brd file. Assuming everything is right you can just type hello form at the Command and it will pop up a form.
  • DE202408202727
    DE202408202727 over 13 years ago
    Did you save the form in the same folder as your brd file? Check also that the name of the form matches exactly the one in the axlFormCreate line of the code.
  • budnoel
    Saving the form in the same directory as my board file was the trick.  Thanks, Dave.  You're the best!!
  • JuergenWeber
    JuergenWeber over 13 years ago
    Allegro looks at for configuration files in the following default locations:
    Cadence provided default configuration files: <cdsroot>/share/pcb
    Site (company) provided location (this is called CDS_SITE):<cdsroot>/share/local/pcb
    see attached PDF
    BR,
    Jürgen
    Site_Env.pdf
