  3. Setup proper order of pdf pages
  • Views 14991
budz
budz over 13 years ago
Is there a script or skill we could use to setup the proper order of pages using the pdf publisher for multiple pages? I am using 16.6 pcb editor.
  • admin
    admin over 13 years ago
    hi , not that i know of such an existing function.
    you may need to write a function for that.
    the pages are referring to the artwork films which have been set up initially?
    your function must be able to sort the artwork films, so it would be better if the film names start with "01-xxx" "02-xxx" ... "11-xxx"
    then send it to the printer, this part i think can only be done with scripts
    hope it helps.
