  3. Cline2shape need changed to Board Outline Layer
  • Views 15365
msalberg
msalberg over 13 years ago
Hi Group,
I have this cline2shape.il file from years past. We changed it to convert a cline to shape on ROUTE KEEPOUT_ALL and has worked great for years.
Now, I would like to change it to convert a cline to BOARD GEOMETRY > OUTLINE but it fails and reports cannot create a “filled” shape on this layer.
Please see both attached files.
Question, does anyone know how to make this file do the following.
1.       Display BOARD GEOMETRY > OUTLINE LAYER and ROUTE KEEPOUT_ALL layers.
2.       Convert the cline to BOARD GEOMETRY > OUTLINE layer as a “unfilled” shape.
3.       Z-Copy the BOARD GEOMETRY > OUTLINE shape to a “filled” shape on ROUTE KEEPOUT_all layer. (expanded 5mil larger than outline.
When all said and done, we should have a routed channel on OUTLINE layer with Route Keepout_All shape 5 mil larger.
Thanks in advance!
Mark
cline2shape_outline.il
  • aCraig
    aCraig over 13 years ago
    To create an unfilled shape change the axlDBCreateShape's second variable from t to nil.
    Craig
  • msalberg
    Thanks for the reply Craig. I will pass it on to our skill guy and try it out.
