  3. Where to copy .il files (total process)
  • Views 15165
PAVANRKS
PAVANRKS over 13 years ago
Hello Skill gurus,
     Can any one help me to what process i need to follw to run skill (.il) files.
Good day,
Pavan Kumar Kulkarni
  • oldmouldy
    oldmouldy over 13 years ago
    Locate the HOME directory, usually C:\SPB_Data set during installation, in there will be a "pcbenv" directory once PCB Editor has been run. In that directory, create a text file called allegro.ilinit, contents as follows:
    ; Setting the LoadDebug variable will turn
    ; on printing the name of each file as it is loaded.
    ; set the full path to the SKILL directory between the quotes in the following variable
    ; NOTE: the direction of the slash characters, these are the required delimiters!
    UserSkillPath="C:/Work/ConfigureLocalSkillLocation/master"
    ; set the LoadDebug to "t" (no quotes) to enable loading messages
    LoadDebug=nil
    if( LoadDebug==t then printf("\n"))
    (foreach file (rexMatchList "\\.il$" (getDirFiles UserSkillPath))
    if( LoadDebug==t then printf("Loading Skill file: %s\n" file))
    (load strcat(UserSkillPath "/" file))
    ; Load any ini files (containing axlCmdRegister)
    (foreach file (rexMatchList "\\.ini$" (getDirFiles UserSkillPath))
    Edit the "UserSkillPath" to specify where your SKILL, IL, files are stored, avoid spaces in the directory names. Set the LoadDebug to "t" to get a list of teh IL files while they load, if required, Start PCB Editor and the IL files will be loaded.
  • PAVANRKS
    Hi Oldmouldy,
    Thank's for the help.
    Good day,
