  3. Allegro "Layer Priority"
  • Subscribers 166
  • Views 8272
Lock2002
Lock2002 over 13 years ago
Is there some trick to getting "layer priority" to work everytime? It works on one design but then it doesn't work on the next. It's pretty straightforward; add the layer that you want displayed on top to the "prioritized layers" window and apply. For some reason it's not working all the time. Anyone else get this?
  • AnthonyK
    AnthonyK over 13 years ago
     I'm running 16.6 P004 and have exactly the same problem.
    One design will work and another won't.  Can't see a common factor that might be the problem.
    When it doesn't work,  the display order does not follow the preferences set up in "layer-priority" when printing.  I've disabled custom colrs in the color dialog (I have color overrides on some nets) and I've set the active subclass to one that is not displayed (following clues in the help file).
    Anyone care to step up to the plate on this one?
  • steve
    steve over 13 years ago
    You are running the base release (which I would say isn't ideal), get the latest hotfix from Cadence / Channel Partner but the issue is normally it because the tool uses the Active Class/subclass first then the Layer Priority so change your Active Class / Subclass to something you are not using and see if that helps. The active class / subclass is listed in the Options menu (if you ahve no active command or is on the bottom of the screen in the middle next to the cor-ordinates. See if that helps.
  • AnthonyK
    Thanks Steve.  The help file notes this also.  As it happens when I revisited my design the plot layer priority was working but I'm not sure if I was doing anything different.  Probably finger trouble at my end as I'm sure more people would be complaining if such a basic function was truly broken.
    On the subject of "the latest hotfix" I stayed in maintenance on 16.5 for a year and Cadence were issuing monthly bug fixes.  I know the products are complex but monthly bug fixes?  Maybe they should do more in-house software testing before a major release rather than rely on the users to find the bugs.  Just a thought...
  • steve
    They are more than bug fixtures. They now include new and improved funcitonality (like 3D STEP file support) so it's more than worth updating.
  • JuriV
    JuriV over 5 years ago in reply to steve
    Unfortunately in the 17.4 S017 the Layer Priority works unstable. Some times is ok, some times not
