  3. axlAirGap pin soldermask to via etch measure
  • Views 16329
Ejlersen
Ejlersen over 13 years ago
Hi
I've been working with the axlAirGap function to find the airgap between a pins soldermask and a vias etch.
However the different options either give me
soldermask to soldermask or etch to etch
Amongst others things I've tried
axlAirGap(oid did "PIN/SOLDERMASK_TOP" 'enhanced)
axlAirGap(oid did "PIN/SOLDERMASK_TOP" 'anyLayer)
where oid is the pin dbid and did is the via dbid
Anyone have a solution to this or how it can be done?
Currently the only way I can see around this problem is to create a duplicate of the via form on another layer and measure the airgap there. I'm well aware that soldermask to pad and cline does this check - but I need it for another purpose.
Thanks in advance
Best regards
Ole
  • DE202408202727
    DE202408202727 over 13 years ago
    Hi Ole,
    I think that there are a number of ways of doing this. None are completely trivial.
    1/ Use axlPadStackEdit copy the via etch "shape" to the via soldermask layer. Wrap this in an axlTransaction and roll back after all your measures.
    2/ Create a temporary shape, the same size as the via etch pad, on the soldermask layer.
    3/ Do the measuring maths yourself. The axlAirGap command should be able to be emulated relatively easily for simple shapes like circles and rectangles.
    Cheers,
    Dave
  • Ejlersen
    Hi Dave
    Thanks for your reply.
    So far I'm thinking 1 or 2 - that should eliminate the risk of me doing a wrong math operation in some corner case.
    I'll probably be copying to a user defined layer that I can delete after use. Using the existing via class or pin class can accidentially create issues, a user could place a via inside a pad and then it would still pick the soldermask to soldermask distance.
    Best regards
    Ole
  • DE202408202727
    Hi Ole,
    Here's a little utility that might help:
     defun( DE_padToPadAirGap (pinOrVia1, pinOrVia2, @key (pad1layer "ETCH/TOP"),  (pad2layer "ETCH/TOP"))
     let((pad1, padPoly1, shp1, pad2, padPoly2, shp2, gap)
    pad1 = axlDBGetPad(pinOrVia1, pad1layer, "REGULAR")
    padPoly1 = car(axlPolyFromDB(car(pad1 ->figure)))
    shp1 = car(axlDBCreateShape(padPoly1, t, "PACKAGE GEOMETRY/DISPLAY_TOP"))
    pad2 = axlDBGetPad(pinOrVia2, pad2layer, "REGULAR")
    padPoly2 = car(axlPolyFromDB(car(pad2 ->figure)))
    shp2 = car(axlDBCreateShape(padPoly2, t, "PACKAGE GEOMETRY/DISPLAY_TOP"))
    gap = caddr(axlAirGap(shp1, shp2))
    axlDeleteObject(list(shp1, shp2))
    gap
    Cheers,
    Dave
  • Ejlersen
    Hi Dave
    Thank you for this, seems like a no brainer for me to work get your code to work for the remaining tasks in my new utility.
    I'm hoping this will sort my last issues before final test and release :-)
    Best regards
    Ole
