  3. How to import artwork by Skill
  • Views 16172
leonlee
leonlee over 13 years ago
How to import artwork by Skill? which like the command "load photoplot" ( File>import>Artwork...)
I'd like to import artworks by mass treatment. Does Skill can do it?
  • Ejlersen
    Ejlersen over 13 years ago
    Hi
    This is possible using scripts.
    Use getDirFiles and search result for artwork files.
    wrap import->artwork scripts into the skill program.
    For the first file import you will need to specify coordinates for placement.
    For the rest you can reuse origin.
    Depending on the requirement, you would have to invent subclasses or at least check for their existance before placement.
    Notice that only artwork files from PCB Editor can be imported. Also when creating the scripts you wan't to mimic, make sure to mimic all settings to take care of all possibilities.
    Skill code example
    defun( ns_drcsize ()
    let((tmp_file)
    tmp_file = axlDMOpenFile("ALLEGRO_SCRIPT", "tmp", "w")
    fprintf(tmp_file "scriptmode +i +n +w +c\n")
    fprintf(tmp_file "prmed\n")
    fprintf(tmp_file "setwindow form.prmedit\n")
    fprintf(tmp_file "FORM prmedit display\n")
    fprintf(tmp_file "FORM prmedit drc_marker_size %f\n" 2.00)
    fprintf(tmp_file "FORM prmedit done\n")
    fprintf(tmp_file "setwindow pcb\n")
    axlDMClose(tmp_file)
    axlShell("replay tmp")
    when(isFile("tmp.scr") deleteFile("tmp.scr"))
    Best regards
    Ole
  • leonlee
    Thanks Ole, scripts is good method to import artwork by mass treatment. But I think SKILL should offer a command for it, like as axlDetailLoad to load details to load plot file.
