  3. Zoom to selection set
  • Subscribers 159
  • Views 15001
WalterX
WalterX over 12 years ago
 Using skill, is there a way to zoom to the selection set?
  • Randy R
    Randy R over 12 years ago
    Check out the axlZoomToDbid() command and see if that will work for you.
  • WalterX
     Oh - it does a list too :) - Will give it a shot.
  • WalterX
     Indeed it works - however it's not a very tight zoom.  Is there a notion of "zoom percentage" in Allegro?
    Side note:  AutoCAD uses a large public variable list which controls behavior of certain actions - does Allegro have a similar thing?
  • Randy R
    axlZoomToDbid() puts the selected objects extents in about 20% of the display.  You can use axlWindowBoxGet(), update the values to your desired zoom factor and then use axlWindowBoxSet().
