  3. Force a callback when a form is canceled?
  • Views 15390
mikebystedt
mikebystedt over 12 years ago
I've got a close button on my form, but is there a way to force a similar callback to be invoked
when the upper right "X" button is clicked?  I'd like to make sure that I do some highlight cleanups
when my form gets closed reguardless of how the user dismisses the form.
Thanks, -Mike
  • DE202408202727
    DE202408202727 over 12 years ago
    You need to name your close button correctly. From memory it should be "cancel" but it may be "quit".
  • fxffxf
    fxffxf over 12 years ago
    Even if you don't label the buttons in a standard manner you can check the doneState attribute. When the menu bar 'X' is selected the doneState should have a value of 3. See the example code, axlform.il in <cdsroot>/share/pcb/examples/skill/form/basic
  • mikebystedt
    This was perfect.  Worked like a charm. Thank you both for pointing me in the right direction on this!
    Very much appreciated!
    -Mike
