  3. Axlairgap help?
  • Views 15091
Axlairgap help?
luanvn81
luanvn81 over 12 years ago
 Hi all.
  I try to get air gap between a route keepout shape with a shape's void by using axl airgap and the result  always return nil. And I don't know where is wrong in my code, I have measured them in layout and airgap is exist.
 The code is posted below,  please help me repair it.
;#### Main Process ####
foreach(void AllVoids    ; voids in shapes on ETCH/BOTTOM LAYER
void_bBox = void->bBox
void_bBox_x1 = xCoord(car(void_bBox))
void_bBox_y1 = yCoord(car(void_bBox))
void_bBox_x2 = xCoord(lastelem(void_bBox))
void_bBox_y2 = yCoord(lastelem(void_bBox))
void_xy = axlDBAltOrigin('center void)
void_size_x = max(void_bBox_x1, void_bBox_x2) - min(void_bBox_x1, void_bBox_x2)
void_size_y = max(void_bBox_y1, void_bBox_y2) - min(void_bBox_y1, void_bBox_y2)
if(void_size_x > minimum_size_shape || void_size_y > minimum_size_shape then
check_area = list(axlMXYSub(car(void_bBox) add_value_list) axlMXYAdd(lastelem(void_bBox) add_value_list))
axlVisibleDesign(nil)
axlVisibleLayer(keepout_layer t) ; ROUTE KEEPOUT/BOTTOM layer
axlShell("redisplay")
axlSetFindFilter(?enabled '(noall Shapes ) ?onButtons '(noall Shapes))
data_in_box = axlGetSelSet(axlSingleSelectBox(check_area))
axlClearSelSet()
if(length(data_in_box) > 0 then
    foreach(item data_in_box
        air_gap = axlAirGap(void item nil 'anyLayer)
        ;if(air_gap < airgap_value then
            ;axlDeleteObject(item)
            fprintf(writeOutFile "%L %L\n", air_gap, void_xy)
        ;);end if
    );end foreach
);end if
);end if
);end foreach
Tks,
Luan
  • edaMac
    edaMac over 12 years ago
    I think you cannot use objType void for axlAirGap, even in manual measure you cannot use void as input. But you can use other segs or even create a temporary shape for the void for the purpose of axlAirGap. Hope this helps.
  • luanvn81
    Hi edaMac!
      Thank for your reply, as your advice, I convert void dbid into r_path by function axlDB2Path, and then create shape with that r_path. After that, I can use axlairgap as usual.
    Tks,
    Luan.
