  3. axlDBOpenShape() not working for dynamic shapes
  • Subscribers 163
  • Views 15874
jwhend
jwhend over 12 years ago
Is there away to open a dynamic shape?
I tried axlDBOpenShape(current_shape) and Get  "W- *WARNING* (axlDBOpenShape): Cannot edit a generated shape."
I use this to open static shapes and it works fine, but need to be able to open both.
Jerry
  • fxffxf
    fxffxf over 12 years ago
    For dynamic shapes, you must open the dynamic shape (BOUNDARY class) not the generated shape (ETCH class).
    To obtain the boundary shape from a generate shape (assumes  generatedShape is the Skill variable hold the shape dbid)
        boundaryShape = generatedShape->shapeBoundary
  • jwhend
    Is there a way to test if a shape is static or dynamic?
    I figured this part. Just didn't scroll down far enough in your reply. Also, what is the function to open the shape BOUNDARY class?
    Jerry
  • fxffxf
     if you have a dbid of a shape the:
        if  dbid->shapeBoundary is nil then you can use dbid to open the shape
        if dbid->shapeBoundary is non-nil then pass  dbid->shapeBoundary to open the shape
    If you finding shapes by using axlSetFindFilter method then you can add "BOUNDARY_SHAPES" to the list of items passed to the '?enabled' option and find will automatically promote a found shape to its owning dynamic shape.
  • jwhend
    Great! Works like a charm.
    Jerry
