  3. [APD] how to retrieve values from constraint manager
  • Views 14862
Guye
Guye over 12 years ago
Hello all,
how can i get the value of bbVia to bbVia spacing (on specific layer)?
 see attachment
i would like to get the marked value.
Guy
  • Kadar
    Kadar over 12 years ago
    Try this:
    If You know the Spacing set name - i.e. "POWER" so You can do this:
    axlCNSGetSpacing("POWER"  "CONDUCTOR/TOP"  'bbvia_bbvia)
    => 5.0
    (instead of "CONDUCTOR/TOP" can be any existing metal layer)
    If You don't have Spacing set name You can find it:
    1) Get the design ID with:  Des_ID=axlDBGetDesign()
    2) Get the nets of Your design D_Nets=Des_ID~>nets
    3) Scan the list of nets and find the desired NET.
    4) For the desired net do:  Desired_Net~>prop~>SPACING_CONSTRAINT_SET
    If You get "nil'' for SPACING_CONSTRAINT_SET it means that its value is "DEFAULT"
    Hope it is helpful.
    Kadar
