  3. data comparison OR use variable without the ""
  • Subscribers 163
  • Views 1687
Guye
Guye over 12 years ago
 when assigning a variable with a text or a number there are "" with it.
for example:
aaa="name"
aaa will be "name" and not name .
same with numbers.
bbb="0.0"
bbb will be "0.0" and not 0.0
 is there any way to remove the ""?
when using this varible - the comparison is problematic.
see example:
if(aaa=name then
do something
else
do something else
is there any way to remove the "" or just ignore it when using the variable?
Guy
  • Randy R
    Randy R over 12 years ago
    Try one of these:
    aaa='name
    or
    if( stringToSymbol(aaa)=='name then
  • Guye
    Thanks!
    it works just fine.
    one other issue, how can i print (printf/fprintf etc.) a sentence without the ""
    for example:
     fprintf(list("the time is:" getCurrentTime())
    this prints:
    "the time is:" `the current time`
    i would like to print:
    the time is: `the current time`
    thanks,
    Guy
  • Randy R
    Try this:
    fprintf("the time is: %s\n" getCurrentTime())
