  3. Net Class to Dummy net spacing
  • Subscribers 163
  • Views 18508
Mstrghettorigg
Mstrghettorigg over 12 years ago
Hi All,
I am looking for a way to set constraints between a Netclass I have to the dummy pins.
I have some high voltage area that requires much bigger spacing than rest of the circuit that is causing me some headache in getting the required spacing.
 I would like to keep the default setting for lower voltage area and adjust the constraints by using net class to net class spacing.
I have grouped few nets to Net Class "A" and  another set to Net Class "B".  I am able to set the constraints so that spacing between default, "A", and "B" is what I want, but the spacing from "A" to Dummy net pins or "B" to Dummy net pins remains to be default setting.
Can anyone help me get these required spacing to these dummy nets?
I know using regions that we could get these results, but I would like to avoid the regions if possible for this case.
Thanks in advance.
  • fxffxf
    fxffxf over 12 years ago +1
    type on the allegro command line: cns_dummy_net You can then assign the dummy net's associated with each dummy net pin to a net class
  • Mstrghettorigg
    FYI - I am on version 16.3 still
  • fxffxf
  • Mstrghettorigg
    This is perfect!
     Thanks for the help again!
  • Hawk10
    Hawk10 over 6 years ago in reply to fxffxf
    @fxffxf,
    I need your help,Having same issue like this.
    I have costume made .brd file i have validate(Ref des-Net name same as in schematic) it and export its changes
    to board.It was linked properly.
    But it unroute nets and make it dummy nets and make a new rats net.
    Is there any solution to save routing.Or it can take same name as in schematic rather then dummy net.
