  3. skill code for placing components around circle (polar placement...
  • Replies 18
  • Subscribers 166
  • Views 30943
skill code for placing components around circle (polar placement)
KARPCB
KARPCB over 12 years ago
 Hi ,
Anyone have  skill code for placing components around circle (polar placement) ?
Karthik
  • KARPCB
    Hi All,
     i need skill code for following concept. Experts please help me.
    Step1 : select the required components in layout
    Step2 :Calculate the orgin of the components
    Step3 : enter the radius and angle
    Step3 : find the x and y location on the circle using below formula
    X = R cos(theta)
    Y = R sin(theta)
    P(X1,Y1)
    R=200
    THETA = 30DEGREE
    P(X2,Y2)
    R=200
    THETA = 60DEGREE
    P(X12,Y12)
    R=200
    THETA = 0DEGREE
    Step4: move the component(orgin) and place into the x and y location of the circle
    plesae see the attached image.
    Thanks in advance,
    karthik.
  • DE202408202727
    DE202408202727 over 12 years ago
    How much Skill experience do you have?
    Do you want some example snippets or for someone to write this code for you?
    Dave
  • KARPCB
    Dave,
    Thanks for reply
    Im 1 month experience in skill language. im not expert like you.
    some examples(step1 and 2) its enough for me to do that skill code.
    Karthik.
  • DE202408202727
    Try this code:
    defun( CircularPlace ()
     let((mypopup, syms, symbols, (continue t), centrePt, radiusStr, radius, angle, angleStr, pt, symAngle)
    ; Create the RMB popup options for Done and Cancel:
    mypopup = axlUIPopupDefine(nil (list (list "Done" 'axlFinishEnterFun), (list "Cancel" "axlCancelEnterFun(), continue = nil")))
    axlUIPopupSet(mypopup)
    ; Select and highlight the symbols to arrange:
    axlSetFindFilter(?enabled '("noall", "SYMBOLS"), ?onButtons '("SYMBOLS"))
    while(axlSelect(?prompt "Select symbols..."); will only continue if one or more objects are selected.
    syms = axlGetSelSet()
    symbols = append(symbols, syms)
    axlClearSelSet()
    axlHighlightObject(syms)
    symbols = unique(symbols); We don't want duplicates
    axlDehighlightObject(symbols)
    and(; Stop if user cancels or anything fails
    continue; Don't continue if the user cancelled
    symbols; Only continue if at least one symbol was selected
    centrePt = axlEnterPoint(?prompts "Select the circle centre", ?gridSnap t); Request the circle centre point
    radiusStr = axlUIPrompt("Enter the radius", "200"); Request the circle radius (a string)
    radius = readstring(radiusStr); Convert the string to a number
    numberp(radius); Ensure that the radius is actually a number
    angle = 360.0 / length(symbols); Calculate the expected delta angle between symbols
    angleStr = axlUIPrompt("Enter the angle", sprintf(nil, "%L", angle)); Allow the user to select an angle
    angle = readstring(angleStr); Convert the string to a number
    numberp(angle); Ensure that the angle is actually a number
    angle = float(angle); The angle needs to be real for axlGeoRotatePt.
    pt = list(car(centrePt) + radius, cadr(centrePt)); This is the starting point.
    symAngle = 0.0; This is the starting angle. *** Change to 90.0 if the component requires it ***
    foreach(sym, symbols
    pt = axlGeoRotatePt(angle, pt, centrePt); Calculate the next point
    symAngle = symAngle + angle; Calculate the next symbol angle
    axlTransformObject(sym, ?move axlMXYSub(pt, sym ->xy), ?angle symAngle - sym ->rotation); Move the symbol.
    Dave
  • KARPCB
     Thanks a lot Dave.
    - karthik.
