  3. axlSelectByProperty
  • Views 14601
axlSelectByProperty
Kot13
Kot13 over 12 years ago
Hi all,
I have a script that places external DRC's into a design based off of some checks that are performed. Mostly spacing checks.
I'm trying to generate a list of only the external DRC's by using the command:
   axlSelectByProperty("DRC", "EXTERNAL_VIOLATION_DESCRIPTION")
However it always return:
   nil
If I use the following code I can get my list:
axlSetFindFilter(?enabled (list "noall"  "DRCS") ?onButtons (list "DRCS"))
Drc_List = axlGetSelSet(axlAddSelectAll())
then I can use to determine what type of DRC each on is:
foreach((drc Drc_List drc_t = drc-> type println(drc_t))) --->
"DESIGN"
"DESIGN"
"EXTERNAL REFERENCE"
I have tried various syntax for the axlSelectByProperty() command but always get nil returned.
Am I using the command correctly? If not can somebody help me with the correct syntax?
Thanks in advance,
-K
  • fxffxf
    fxffxf over 12 years ago
    An easier and faster method:
         design = axlDBGetDesign()
         waivedDRCs = setof(item design->drcs item->type == "EXTERNAL REFERENCE")
    If user might have waived some them also do 'setof' on deisgn->waived
  • Kot13
     Thanks a lot!
    This method is working and is much better than the path I was going down.
    As for the axlSelectByProperty method, I used that as a referance from some skill code that I found on line. Looks like maybe a property name has changed between Allegro releases...
    Thanks again,
    -K
