  3. SKILL code to detect empty cells while parsing CSV file
  • Replies 7
  • Views 21606
BinduSripad
BinduSripad over 12 years ago
Hi SKILL experts,
I am trying to parse a CSV file and populate this data into a hash table. The CSV file could possibly have empty cells. If any of the first 7 columns for a given row in the CSV file is empty, the parser should stop and not write the data to the hash table.
Although when the line is read from the CSV file and written to a list, an empty cell is recognized as highlighted below:
 before parsing :"PCB Rules, SilkScreen Checks,SilkText to Exposed Pad Spacing,,Text to exposed ViaPad Spacing on Top Layer,axlformbmp1.bmp,silktxt_exposed-spacing.txt,MIN_TXT_TO_VIAPAD_TOP_DIST,FLOAT,1,,,"
After parsing the line using parseString(_line “,”) , the output is as follows. The empty cell is not being detected:
 after parsing :("PCB Rules" " SilkScreen Checks" "SilkText to Exposed Pad Spacing" "Text to exposed ViaPad Spacing on Top Layer" "axlformbmp1.bmp" "silktxt_exposed-spacing.txt" "MIN_TXT_TO_VIAPAD_TOP_DIST" "FLOAT" "1")
 My code snippet is as follows. Please let me know of any other string parsing function in SKILL which can detect spaces (empty cells read from CSV file). Or if I can use a combination of comma and spaces (more than 2) as ‘breakCharacters’.
 _returnLine = nil
_lineCount = 1
when(_inFile
while(gets(_newData _inFile)
when(_newData !="\n" && _lineCount > 1
_returnLine = ()
;; read each line from the csv file into a string
_textLine = car(parseString(_newData "\n"))
printf("\nbefore parsing :%L" _textLine)
;; parse the string with comma as the separator
_returnLine = parseString(_textLine ",")
printf("\nafter parsing :%L" _returnLine)
;; read the parsed fields
_ruleType = nth(0 _returnLine)
_category = nth(1 _returnLine)
_workbook = nth(2 _returnLine)
_ruleFile = nth(3 _returnLine)
_ruleName = nth(4 _returnLine)
_bitmap   = nth(5 _returnLine)
_document = nth(6 _returnLine)
;; populate the hash table only if the first 7 columns for each row are not empty
if( (_ruleType != " ") then
if( (nth(1 _returnLine) != " ") then
if( (nth(2 _returnLine) != " ") then
if( (nth(3 _returnLine) != " ") then
if( (nth(4 _returnLine) != " ") then
if( (nth(5 _returnLine) != " ") then
if( (nth(6 _returnLine) != " ") then
_rule->ruletype = nth(0 _returnLine)
_rule->category = nth(1 _returnLine)
_rule->workbook = nth(2 _returnLine)
_rule->ruleFile = nth(3 _returnLine)
_rule->ruleName = nth(4 _returnLine)
_rule->bitmap   = nth(5 _returnLine)
_rule->document = nth(6 _returnLine)
;; insert this structure into hash table with rule name as key
ruleTable[nth(4 _returnLine)] = _rule
);when
;; move to next line
_lineCount = _lineCount + 1
);while
close(_inFile)
);when
Bindu
  • DE202408202727
    DE202408202727 over 12 years ago
    axlStringCSVParse has been provided for exactly this reason.
  • BinduSripad
    Thanks for the quick response, Dave!!  Yes, 'axlStringCSVParse' works perfect.
  • mikebystedt
    mikebystedt over 12 years ago
    Big fat warning on using axlStringCSVParse().
    Passing it a string over 1024 characters will CRASH Allegro.
    Some folks at Cadence aren't doing proper testing.  SKILL strings are not limited to that number.
    And when the whole thing crashes, good luck with debugging anything.
    Now trying to figure out a workaround so I don't have to attempt to write my own custom parser.
    I need all of the benefits of this function, but without the size limitation.
    -Mike
  • DE202408202727
    Thanks for the warning. Did you raise a case with Cadence?
    Here's a clunky work around:
    defun( DE_StringCSVParse (txt "S")
     let((unusedChs, dummyCh1, dummyCh2)
    unusedChs = setof(ch, parseString("\t\f\r\n\v^~@#$%&*-_+={}[;:,.<>?|", ""), !index(txt, ch)); Assumes that at least two of these characters are unused.
    dummyCh1 = car(unusedChs)
    dummyCh2 = cadr(unusedChs)
    rexCompile(",")
    txt = rexReplace(txt, strcat(dummyCh1, dummyCh2), 0)
    rexCompile(dummyCh2)
    mapcar(lambda((x), rexReplace(x, "", 0)), parseString(strcat(dummyCh2, txt), dummyCh1))
  • DE202408202727
    This works better:
    defun( DE_StringCSVParse (txtLine @optional (delimCh ",") "tt")
     let((lst, (str ""), doubleQuoted, quoted)
    rexCompile("\n"), txtLine = rexReplace(txtLine, "", 0); Ignore crlf characters.
    foreach(ch, parseString(txtLine, "")
    cond(
    (ch == delimCh && !doubleQuoted && !quoted, lst = tconc(lst, str), str = ""); Add the string to the list when a comma is encountered and not withing quotes.
    (ch == delimCh && (doubleQuoted || quoted), str = strcat(str, ch)); Just add to the string when a comma is encountered withing quotes.
    (ch == "\"" && !quoted, doubleQuoted = !doubleQuoted); Don't separate on commas within a double-quoted string. Include the double-quotes characted if it's within quotes.
    (ch == "'" && !doubleQuoted, quoted = !quoted); Don't separate on commas within a quoted string. Include the quote mark if it's within double quotes.
    (t, str = strcat(str, ch)); Just add to the string for ordinary characters.
    car(tconc(lst, str)); Return the list
