  3. Check if File exists in SKILL
  • Subscribers 163
  • Views 23792
BinduSripad
BinduSripad over 12 years ago
I am trying to check if a given file exists in one of the directories listed in the parent of parent of current directory (2 levels up)
Code:
 isFileName(ruleFile list("..." ) )
This doesnt seem to be correct.
Could you please suggest a solution for the same. Is there an alternate to varying the SKILL Path?
Bindu
  • fxffxf
    fxffxf over 12 years ago
    You may want to try axlDMFindFile which ignores the skillPath variable. For examle to find a file up 2 levels do
    sprintf(buf "../../%s"   ruleFile)
    result = axlDMFindFile("MISC" buf "r")
    if result is nil then file does not exist.
    It is also best to use UNIX style directory delimiters  ( "/") instead of Windows style ("\") since you don't need escape the UNIX version.
    In general, getDirFiles should be avoided if performance will be an issue.
