  3. Check if File exists in SKILL
  • Subscribers 163
  • Views 23791
BinduSripad
BinduSripad over 12 years ago
I am trying to check if a given file exists in one of the directories listed in the parent of parent of current directory (2 levels up)
Code:
 isFileName(ruleFile list("..." ) )
This doesnt seem to be correct.
Could you please suggest a solution for the same. Is there an alternate to varying the SKILL Path?
Bindu
  • Randy R
    Randy R over 12 years ago
    See if this works for you.  Just replace filename.txt with your filename.
    isFileName("filename.txt" "..\\..\\")
  • BinduSripad
    Hi Randy,
    Thanks for the suggestion!
    But it is not working as expected.
    In general, how is a file searched in multiple/hierarchy of directories in SKILL?
    Bindu
  • Aldrin
    Aldrin over 12 years ago
    The suggestion by Randy R actually works. Alternatively,if you have defined path to search.. you can use the isFile(filepath) command.
    For file multiple file searching, you may use getDirFiles then loop.
  • Aldrin
     *For multiple directory/hierarchy searching, you may use getDirFIles then loop on the result.
  • BinduSripad
    Hi All,
    This works :
    ;;  you can change the directory depth based on requirement
    _fileList = getDirFiles("../../../")
    if( exists(_file _fileList (stringp _file))
    then
         _checkFile = "True"
    else
    printf("\nFile %s not found!" _file)
    );if
    Thanks for the helpful pointers!!
    Bindu
