  3. Can't set popup
  • Views 2548
Can't set popup
Tiger LIU
Tiger LIU over 12 years ago
I can't set popup unless app mode is "none".
Here is the code, I am using SPB16.6 with hotfix030.
Thanks a lot.
 (defun cbc_select ()
let(()
    cbc_select_popup = axlUIPopupDefine( nil (list     (list "Complete" 'cbc_select_complete) (list "Cancel" 'cbc_select_cancel ) ))
    axlUIPopupSet(cbc_select_popup)
    axlClearSelSet()
    axlSetFindFilter( ?enabled list("noall" "COMPONENTS") ?onButtons list("noall" "COMPONENTS"))
    axlSelect(?groupMode t ?prompt "Select objects you want to highlight.")
);let
);defun
  • Tiger LIU
     Hi,anyone could help?
    Thanks.
  • DE202408202727
    DE202408202727 over 12 years ago
    Try this:
     let(()
    axlClearSelSet()
    while(axlSelect(?groupMode t ?prompt "Select objects you want to highlight."), t)
    axlUIPopupSet(nil)
    );let
    );defun
  • Tiger LIU
     Hi Dave,
    Thanks for your reply, but that doesn't work.
    I have to set appmode to "none" before run this function to see the popup.
  • DE202408202727
    I see what you mean. I can't get this to behave consistently either.
  • Tiger LIU
    Perhaps this is a bug or is there anything wrong with my code?
