  3. Changing property source
  • Views 13828
joelsprunger
joelsprunger over 12 years ago
With regards to allegro schematic capture: I would like to change the ROOM property source from a hierarcicle block to the top level. I would like to do this without the need to click on individual items and select the source from the drop-down menu. If I could do this with a SKILL script or command prompt that would be best.
The main goal is to be able to put components in a block into a ROOM without putting other components in other instances in that same ROOM.
