  3. axlDBCreateSymbol issue with mechanical symbols
  • Views 15756
Ejlersen
Ejlersen over 12 years ago
Hi
I'm seeing something really weird here, hope someone can help me out.
I've created some code to place components but are seeing issues when trying to place mechanical symbols
corn.dra is a mechanical symbol with a resulting .bsm in the symbols subdir
corn.txt is the device file needed for the axl functions.
If I do
p = axlDBCreateComponent("xyz1" "corn")
Then the part is created without any issue
Howeven when I try to place it I get an error message
p = axlDBCreateSymbol("xyz1" 0.0:0.0 nil 0.0)
E- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.
But If I go into standar place->manually then I can place the component without any issue.
Anyone with an idea as to whats causing this issue?
It's on purpose that the part needs a refdes for a mechanical part and not just a normal mech part.
Best regards
Ole
axlDBCreateSymbol.zip
  • DE202408202727
    DE202408202727 over 12 years ago
    Hi Ole,
    There are two syntaxes for  axlDBCreateSymbol. I suspect that when you manually place a mechanical symbol it uses the equivalent of the symbolData method. Do you really get a refdes on the manually placed mechanical component?
    Regards, Dave
  • Ejlersen
    Hi Dave
    yes, I'm getting a refdes if I place it using the normal Place->Manually dialog after running the first command, you can see that in the board from the sample file.
    I'm already using both methods for axlDBCreateSymbol but for different purposes - if the component I want to place don't have a refdes then I use axlDBCreateSymbol('("fiducial" "mechanical") .....) but if it does have a refdes I use create component and then dbcreatesymbol - if The clas's for the component is "Mechanical" that's possible in front to back flow.
    best regards
    ole
  • DE202408202727
    Hi Ole,
    Yes, that does make sense. I try to avoid using mechanical symbols in that way but I now remember having done it before.
    I think you are on the way to needing to raise a service request for this. It shouldn't crash.
    Cheers,
    Dave
  • Ejlersen
    Hi Dave
    SR created and waiting for response :-)
     Cheers
    Ole
