  3. How can I offset consecutive lines of SKILL generated text...
  • Subscribers 159
  • Views 889
How can I offset consecutive lines of SKILL generated text so that they don't overlap?
thewill2live
thewill2live over 11 years ago
Hey guys,
I have a SKILL script that is creating a series of lines of text as such:
1.0 This is line 1
1.1 This is line 2
1.2 This is line 3
I am creating them using the axlDBCreateText command and it works fine but the lines come out slightly overlapping each other (for instance where the bottom of a 'p' or 'y' sticks down it hits the top of the character below it. Is there a way to fix this so that the lines offset from each other a bit so that there's a gap between lines?
  • eDave
    eDave over 11 years ago
    You need to adjust your text block parameters. Set the "Line Space" to a bigger number. There is no easy way to avoid vertical text clashes without doing this.
  • thewill2live
    Ah perfect! Thank you Dave. I was going about this problem the wrong way, I was trying to fix it locally at each line written instead of globally to the text block.
