  3. Parsing a techfile outside of a Cadence tool revisited yet...
  • Subscribers 159
  • Views 13292
Parsing a techfile outside of a Cadence tool revisited yet again
knuhcrek
knuhcrek over 11 years ago
Greetings all,
Has anyone had any luck parsing a non-xml techfile outside of a Cadence tool ie without using SKILL? Seems this would be tricky for a custom parser what with all the parenthesis that have to jibe and scanning multiple lines etc. Is there a Python or Scheme module available for this?
Chris Walters (back after a LLLLOOOONNNNNNGGGGGGG absence)
local rusty guru
Intel
  • oldmouldy
    oldmouldy over 11 years ago
    I think that you might be referring to the "Constraints" (DCF) file, rather than "Techfile" (TCF) which always looks to be XML? In which case the file format is called S-expressions, this is a LISP format but parsers exist for many other languages including Python (it seems), try a web search for "Python parse s-expression" which should get you some Python answers which may help.
