  3. Some STEP Files Don't Work
  • Replies 13
  • Subscribers 172
  • Views 13215
mckeen
mckeen over 11 years ago
I am trying to use the 3D step package mapping capability in Allegro (16.6 S038), but find that many step files don't work.  I am downloading step files from 3dcontentcentral.com.  I find some work just fine, but others do not show up in the mapping window preview or when in the 3D rendering of the PCB.  I am pretty sure there is nothing wrong with the step files because I am able to load and view them fine in Solidworks.
Is anyone else experiencing this problem or have any suggestions/workarounds?
  • Nodaru
    Nodaru over 6 years ago +1
    Hi, I just add the same issue. With some design I was able to see step files in the STEP_MAPPING viewer and with some other it wasn't the case. The issue happens when my .brd file is located in a directory…
  • oldmouldy
    oldmouldy over 11 years ago
    Do you have any specific examples? Sources like 3D Content Central are user contributed but usually pretty good quality nonetheless. You can occasionally get issues with incorrect units, like mm read as inches, this is quite rare but will definitely get some strange behaviour. Large, >35Meg, STEP files may cause issues but, again, these are not especially common.
  • padmaster
    padmaster over 11 years ago
    Haven't had problems bringing STEP files into Allegro footprints but when I export a STEP file from Allegro and try to open it in Solidworks, Solidworks crashes everytime. Still not fixed in SW2015.
  • cadSmith
    cadSmith over 11 years ago
    I was having this problem in the past.  Try changing the units in the step export window.  Going from mm to mil (or the other way around) fixed it for me.
  • JFuoco
    JFuoco over 10 years ago
    I'm having a similar issue, and have had it on about 2/10 components. A specific example is this TO-263 package:
    When I go to map it, the preview window comes up empty, as shown here:
    Any ideas?
  • steve
    steve over 10 years ago
    This just works for me so check:- that your STEP file is stored in a location controlled by your steppath. You have an open filename.dra or filename.brd, you are not running the base release (Ideally the latest hotfix).
