  3. Allegro PCB --> Export Placement ????
  • Replies 12
  • Subscribers 166
  • Views 19805
split63
split63 over 11 years ago
I have a two sided PCB and the goal is to generate two placement files; one for the top, and one for the bottom.
How is this accomplished?
Currently if I run File --> Export --> Placement, it generates one file with the top and bottom components mixed together in one file.  Also the bottom side coordinates appear to be relative to the top origin looking through the board.
Tools --> Reports -->Component report  seems to generate the same mixed result.
  • split63
    How do you control if the data is relative to body center or pin 1?
  • chads108
    chads108 over 11 years ago
    The report you are creating should be relative to the symbol origin.
  • split63
    Looking in the files, I see:
    PIN_X, PIN_Y
    SYM_X,SYM_Y
    Is Sym == Symbol == Body Center?
    Is PIN==Pin1
  • oldmouldy
    oldmouldy over 11 years ago
    Apologies for the True / False foul up, should have tested before posting! SYM_X and SYM_Y will be location of the Symbol origin on the board, viewed from above. The Symbol Origin will be where the "0,0" point is on the library symbol from when it was designed, this would typically be Body Centre for Surface Mount and Pin 1 Centre for Through Hole but it doesn't have to be that! The assembly house will compensate for the location they require from the details that you provide about the values in your placement data.
  • olebon
    olebon over 6 years ago in reply to oldmouldy
    Do you know where disappeared menus "File - Export" or "Tool - Reports"? This thread is the only source of XY data export in ORCAD :(
