  3. Allegro PCB --> Export Placement ????
  • Replies 12
  • Subscribers 166
  • Views 19811
split63
split63 over 11 years ago
I have a two sided PCB and the goal is to generate two placement files; one for the top, and one for the bottom.
How is this accomplished?
Currently if I run File --> Export --> Placement, it generates one file with the top and bottom components mixed together in one file.  Also the bottom side coordinates appear to be relative to the top origin looking through the board.
Tools --> Reports -->Component report  seems to generate the same mixed result.
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to olebon
    just type in the command 'reports'
    then double-click 'component report'
    then the 'Generate report' button at the bottom
  • mcatramb91
    mcatramb91 over 6 years ago in reply to olebon
    Probably already figured it out, the OrCAD Legacy menu File > Export has moved to a Top Level menu Export
    Export > Pick/Place Data...  (Generic Placement Data)
    Export > Reports   (Standard Reports)
    Hope this helps,
    Mike Catrambone
