  3. Distance DRC Report
  • Views 14765
Distance DRC Report
eddieb1
eddieb1 over 11 years ago
Hello Experts,
I'm looking for a code that will do the following:
1. Create an interactive DRC report where it will show / lists traces that violated the air gap rule.
 The DRC report will show the the x-y coordinate of the trace so that when you select it (x-y), you will be taken to the location of the trace / violation.
ie: segment:xy (4625 2000) xy (3800 2000) width (12)
The report will also show the corresponding layers the trace was routed in.
For example, I'd like to find out if there are traces in my design that are less than 1X away from a pad or a via.
where X = trace width (that is, 6 mils)
Can this be done?
Thanks in advance.
Eddie
  • obwise
    obwise over 5 years ago
    Hey Eddie, I was wondering if you were able to find a solution to your question?  I'm looking to do something very similar.
