  3. Revision Number Alias
  • Subscribers 159
  • Views 13269
nimoster
nimoster over 10 years ago
Hi All
I'm using a revision text string on multiple layers which I have to change manually with every new release. Is there a way of using a wildcard or string variable which I have to change only once and which is automatically updated on each layer? I'm using Allegro 16.5.
Thanks in advance,
Martin
  • B Bruekers
    B Bruekers over 10 years ago
    You can first get all text and then filter the text on layers and/or strings which you want to change.
    l_dbtxt = axlDBGetAttachedText(axlDBGetDesign())
    reg = pcreCompile( "(SOLDERMASK)|(^ETCH/)")
    l_dbtxt = setof(txt l_dbtxt pcreExecute(reg txt->layer) )
    the l_dbtxt now contains items from etch and soldermask layers.
    The same setof you can do for the actual text:
    reg = pcreCompile( "^mystring")
    l_dbtxt = setof(txt l_dbtxt pcreExecute(reg txt->text) )
    And now use the axlDBChangeText to change the text for each text dbID in the list.
    btw, i believe someone posted a text edit utility on this forum a while ago.
