  3. Is there a way to add in Dimensions to a Part through SKILL...
  • Views 14668
Is there a way to add in Dimensions to a Part through SKILL?
thewill2live
thewill2live over 11 years ago
I know the logic behind deciding where to add the dimensions could be a little complicated but is there even a command to add the dimension in? A quick search through the SKILL Reference document isn't returning any commands that might work. Any info is appreciated.
Will
  • DE202408202727
    DE202408202727 over 11 years ago
    There's no easy way (such as "axlAddDimension"). It's worth an enhancement request.
    I do have some code that might help but, if you want to do it yourself, start by adding a symbol skeleton and add lines and text to that.
  • thewill2live
    Thanks for the info, Dave. I think I will have to table this for now and maybe re-evaluate down the line if Cadence ever gets around to adding something like this.
