  3. Fixing or Retaining Net name on vias and cline when disconnected...
  • Subscribers 160
  • Views 14692
Fixing or Retaining Net name on vias and cline when disconnected from component pin
Wale
Wale over 10 years ago
Hi Helper,
Is it possible to use Skill to fix or retain the net name on a via  when the cline that connects to the via disconnects from a component pin?
Wale
  • steve
    steve over 10 years ago
    You can add the property RETAIN_NET_ON_VIAS to the net(s) from the Properties tab of Constraint Manager. Set this to On for the specific net.
    If you want to do it with SKILL then
    Open an Allegro board and add the commands one at a time at the Allegro command line.
    Command > skill
    Skill > dbid_n=axlDBGetDesign()
    Skill > net_in=dbid_n->nets
    Skill > prop_name=list("RETAIN_NET_ON_VIAS" "TRUE")
    Skill > foreach(netn net_in axlDBAddProp(netn prop_name))
    Skill >
    With this all nets will now have the property “Retain_net_on_vias”
