  3. Accessing Symbol properties from SKILL
  • Views 18097
ElectronMonkey
ElectronMonkey over 11 years ago
In Allegro PCB, when I do Show Element from the GUI and select a symbol, it shows something like this:
< SYMBOL>
RefDes:   R7
Properties attached to symbol definition
   PROP1 = blah
   PROP2 = blahblah
How do I access these properties in SKILL?  I want to read and edit/set them.  The properties are defined in the global dictionary.
p=axlSelectByProperty("symbol" "PROP1")
returns nil and does not select anything.
axlDBGetProperties()
never returns anything but nil.
Poking around on the command line investigating symbols and components has not revealed the desired properties.
First, I want to be able to read them, and then I want to modify/add these properties.
Any ideas on how I should be doing this?
Thanks.
  • fxffxf
    fxffxf over 11 years ago
    As you indicated, the properties are on the symbol definition so you would need to do:
         p = axlSelectByProperty("symdef" "PROP1")
    If axlSelectByProperty finds dbids it returns a list of dbids, so to look at the 1st symdef in the list
        symdef = car(p)
    To get the property value
         symdef->prop->PROP1
    To delete the prop off all objects found
         axlDBDeleteProp(p '("PROP1"))
    To modify property with a new value on all objects found
         axlDBAddProp(p '("PROP1"  "foo"))
  • ElectronMonkey
    Excellent!  Thanks, fxffxf.  Those seem to be the main pieces I was missing.
