  3. Skill Debugger
  • Views 17340
Skill Debugger
Lennie
Lennie over 11 years ago
Is there a debugging tool for Skill programs under windows ? I see something about a SKILLDEV license and a skill debugger toolbox. How do I determine if I have a license and if so how do I use it ?
  • Lennie
    It looks like the toolbox for Allegro requires the same toolbox and large cost for Virtuoso. If you do not have these how do you debug skill code ?
  • Randy R
    Randy R over 11 years ago
    Here's some methods I've used.
    1)   Insert line(s) of code to print out variables or computational results at critical places (you can even key them off of a global debug variable)
    2)  Break your code into segments and see if they run okay
  • B Bruekers
    B Bruekers over 11 years ago
    I use the separate skill window to test and debug skill code. Start it with "set telskill"
    Further, to get some more debugging information i use this statement:
    when(axlIsDebug() sstatus(stacktrace 10), sstatus(stacktraceDump t), sstatus(debugMode t ))
    The sstatus statements will show you some more info when the program is stopped due to an error.
    With axlDebug(t) you enable the 'debug' mode.The axlIsDebug() returns t when debugging is enabled. This can be useful for printing variables during runtime.
