  3. How to measure minimum shape width?
  • Subscribers 167
  • Views 20758
luanvn81
luanvn81 over 11 years ago
Hi All!
  I want to measure "shape width" at narrow locations as below image using Skill but I don't know how to do it? Please give me some suggestion.
Tks.
Luan.
  • SadiqAlZaman
    SadiqAlZaman over 10 years ago
    Hi, have you solved this problem? can you help me out
  • luanvn81
    luanvn81 over 10 years ago
    Hi Sadiq Zaman!
      I'm so sorry but up to now I can't find  out the best way to solve that. Hope the expert in this forum can help us. Whenever I have solved, I will post code in here.
    Luan.
  • DE202408202727
    DE202408202727 over 10 years ago
    It is relatively simple using intersection maths because shapes and their voids have easily obtainable boundaries that consist of straight line and circular arc segments only:
    1/ Find the segments of the shape
    2/ Intersect them with your pre-defined line
    3/ Calculate the intersections and add up the distances.
    4/ Find the segments of the voids
    5/ Intersect them with your pre-defined line
    6/ Subtract the distances from your total
    None of these steps is difficult.
  • SadiqAlZaman
    hi Dave
    Thank you for your reply
    I am doing it the same way , by mathematical calculation , but is there a better way to calculated this copper web (copper flow areas )? because if i have void of different sizes , then it is quite time consuming on a large project.
    Is there a tool or skill code or script which can be use for this? Or even any sort of report that i can get from allegro which can provide me this copper web details in my project (.brd)
    Sadiq Al Zaman
  • Jared110700
    Jared110700 over 5 years ago
    Hi Luan,
     And now, Have you solved this problem yet?
