  3. Can't get a skill function to pass a string in as a property...
  • Subscribers 163
  • Views 2026
Can't get a skill function to pass a string in as a property name
wilef
wilef over 11 years ago
In the APD command window with a skill prompt this works fine:
Skill > designDBID = axlDBGetDesign()
Skill > designDBID->prop->"EIGHTY_PERCENT_TEXT_BLOCK"
return value: "37"
But this doesn't work:
Skill > propName = "EIGHTY_PERCENT_TEXT_BLOCK"
Skill > designDBID->prop->propName
return value: nil
Basically I have a skill function that passes in a property name as a string, and I want to get the value of that property on a certain DB object, but it just won't work. What am I missing? As an example, this code won't work:
print(designDBID->prop->propName)
  • fxffxf
    fxffxf over 11 years ago
    try:  get(designDBID->prop propName)
  • wilef
    No, that still doesn't work, still get nil. Thanks though.
  • wilef
    Actually that did work!
