  3. Splitting a large list
  • Subscribers 163
  • Views 14769
vramanax
vramanax over 11 years ago
Hi
Basically I am looking for a way to split a large list into smaller chunks
lets say into minimum chunk size of 100s
I am working on a function myself but I thought I will save some time if any of you can help me to solve it
Regards
Venkata
  • fxffxf
    fxffxf over 11 years ago
    It you are lucky to be on Linux use the split command
    Windows, you can download cygwin package and use the split command on that package. or download perl where code exists to split a file
  • vramanax
    Hi thanks Here is a solution I came up with
    assume a list of objects is more than 100
    then you use the following call
    __bReakList(llist)
    I have 2 procedures
    procedure( __bReakList(_lIst)
    prog((i __rEturnList __ChunkSize __RemainderChunk _tList)
    i=0
    __ChunkSize = length(_lIst)/100
    __RemainderChunk = mod(length(_lIst) 100)
    __rEturnList = list()
    while(i < (length(_lIst) - __RemainderChunk)-1
    __rEturnList = cons(__sPlitList(_lIst i i+99) __rEturnList)
    i = i + 100
    _tList = list()
    for(i length(_lIst) - __RemainderChunk length(_lIst)-1
    _tList = cons(nth(i _lIst) _tList)
    __rEturnList = cons(_tList __rEturnList)
    i = 0
    return(__rEturnList)
    procedure( __sPlitList(iNList sTartIndex eNdIndex)
    prog((_tList)
    _tList = list()
    for(i sTartIndex eNdIndex
    _tList = cons(nth(i iNList) _tList)
    return(_tList)
    it is something,
    I am using this test a bigger program to see if it makes any difference in processing a huge list at one shot or processing them 100 at a time
  • vramanax
    You can modify the procedure to include the chunk size as input instead of hard coding to 100
