  3. Run CreateDir from .il file
  • Subscribers 163
  • Views 15585
irpcbdes999
irpcbdes999 over 11 years ago
hi,
im new in skill.
need to include a createDir and call it from custom menu in Allegro.
Created createDir.il file and placed a code below: added menu to point in the directory with createDir.il, but when clicking on the menu item getting E- Command not found: createDir
/* createDir("./NewDir") ./ is relative path with current working directory
procedure (_createDIr()
createDir("./NewDir1")
printf("NewDir1 was created\n" )
thanks for help
  • fxffxf
    fxffxf over 11 years ago
    You need to see what you are doing in the allegro.men file
    At a minimum you need to have the command in the menu entry as:
        skill  _createDir()
  • irpcbdes999
    Im loading extra menu as dynamic menu, I have two other skill files are working, and two scripts replay work fine. I have this in allegro.ilinit ; Create Dir Skill 8.1
    ;Allegro Command(s) = createDir
    load("createDir.il")
    skill _createDir() ;added your suggestion but didn't work
    ;Dynamic menus for Allegro - New 16.6 SKILL Function "axlUIMenuInsert"
    load("Dynamic_Menus.il") and this in Dynamic_Menus.il file :MENU = '(
    (popup "APPs")
    ("FAB Output" "replay FAB_OUT") ;this one is working
    ("Plot All Layers" "replay Plot_PDF") ;this one is working
    ("Change Net on VIA" "change_vianet") ;this one is working
    ("Create folder in current working directory-prototype)" "createDir") ;this one doesnt work
  • fxffxf
    change: ("Create folder in current working directory-prototype)" "createDir")
    to: ("Create folder in current working directory-prototype)" "skill _createDir()")
    or keep your menu code and add the following Skill statement:
    axlCmdRegister("createdir" '_createDir ?cmdType "general")
  • irpcbdes999
    getting undefined function error
    undefined function - _createDir
    Allegro.ilinit
    ;Create Dir Skill 8.1
    ;Allegro Command(s) = _createDir
    skill _createDir()
    Diynamic Menu.il
    MENU = '(
    (popup "IR APPs")
    ("Plot All Layers" "replay Plot_PDF_6Layer")
    createDir.il
    procedure (_createDir()
