  3. Overrighting attributes of user defined property for a component...
  • Views 16448
Wale
Wale over 11 years ago
I am working a skill script ... as simple as it should be .. i think i am missing something ....  can someone help look into this ????
The script is supposed to call a .txt file which contains list of Refdes and MPN of components... So for each components on the brd file, the script will parse through each on-board component's Refdes and compare it with the Refdes from the list ( one at a time) and if they match, will replace the attribute of a user defined properties (ASI_MODEL)
E.g.... Component  R12 has property ASI_MODEL = H12345 - 001.... will have its property attribute(H12345 - 001)  replaced by the attribute from the file input ( txt file ).. H00000 - 002
Thanks: Wale
xlCmdRegister("rfl" 'RBG_replace_refdes_list ?cmdType "INTERACTIVE" )
defun( RBG_replace_refdes_list ( @optional refdes_ps )
prog( list(refdes_file r_via l_comp_refdes l_comp_ipn)
mypopup = axlUIPopupDefine( nil (list (list "Done" 'refdes_Done)))
axlUIPopupSet( mypopup)
unless(refdes_ps
refdes_file = axlDMFileBrowse("ALLEGRO_TEXT" nil)
if(isFile(refdes_file) then
refdes_data = axlDMOpenFile("ALLEGRO_TEXT" refdes_file "r")
when(refdes_data
axlSetFindFilter(?enabled '(noall components) ?onButtons '(components))
while(l_refdes = lineread(refdes_data)
r_via = nil
l_comp_refdes=nth(0 l_refdes)
l_comp_ipn = sprintf( nil "%L", nth(1 l_refdes))
axlClearSelSet()
println(l_comp_refdes)
foreach(item comp_dbid
comp_refdes = item->name
comp_ipn = item->compdef->prop->PART_NUMBER
if(l_comp_refdes == comp_refdes
then
l_comp_ipn = comp_ipn
println(l_comp_ipn)
println(type(l_comp_ipn))
comp_prop = axlDBGetProperties(item '("user" "allegro"))
if(car(comp_prop) != "ASI_MODEL"
then
comp_prop = axlDBAddProp(item list("ASI_Model", l_comp_ipn))
else
);endforeach
);endwhile
);endwhen
axlDMClose(refdes_data)
return(t)
else
axlMsgPut(list("File %s could not be found.\n" 3) refdes_file)
return(nil)
);endif
);end unless
);endprog
);enddefun
defun(refdes_Done ()
axlFinishEnterFun()
axlUIPopupSet(nil) ;Remove our popup menu.
  • DE202408202727
    DE202408202727 over 11 years ago
    The first this I would do is replace the line: while(l_refdes = lineread(refdes_data)
    with: while((l_refdes = lineread(refdes_data))
  • DE202408202727
    Your then and elseare the same for if(car(comp_prop) != "ASI_MODEL"
  • Wale
    Thanks for your reply Dave..... your first comment helped greatly.... so .. i am trying to compare two strings @ line if(l_comp_refdes == comp_refdes...... these are two variable having string values in them and i am trying to compare them ...... my script would not parse through this point.... is there another way of comparing variables with string values in them ?thanks
  • DE202408202727
    You are comparing a string with a symbol using that method. You might be better with something like this:
    axlAddSelectAll()
    comp_dbids = axlGetSelSet()
    axlClearSelSet()
    while(gets(l_refdes, refdes_data)
      l_refdes = parseString(l_refdes)
      r_via = nil
      l_comp_refdes = nth(0 l_refdes)
      l_comp_ipn = nth(1 l_refdes)
      foreach(item comp_dbids
  • Wale
    Hi Dave.. Thanks for your feed back .. i appreciate it and it does help.....
