  3. RotateSilkAssyRD.il does not "Center Assembly RDs at Part...
  • Replies 11
  • Subscribers 166
  • Views 8489
RotateSilkAssyRD.il does not "Center Assembly RDs at Part Origin"
SMyersPCB
SMyersPCB over 11 years ago
I am using the RotateSilkAssyRD.il SKILL file in which I use it to rotate all of my ref des for my Assembly. However, it doesn't snap the text to the symbol origin that its associated to resulting in me having to use the "Snap pick to..." command and snapping it to the Symbol Origin. When I run the file and check the box for "Center Assembly RDs at Part Origin," it will take all the text for that particular layer and throw it down and to the left. If I run it with the command off, it will leave the text as is and rotate it as I've selected, but it would be nice to have the feature corrected so it snaps to the center so save me time from clean up.
Attached is the SKILL file as I use it today and several screen shots.
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/RotateSilkAssyRD.il
How the file looks before I run the SKILL file, various text in various directions.
How it looks if I run with the option checked, the text is rotated, but its thrown way off and not snapped to the center.
How it looks with the option checked off, the text is correct and its close to the component. I just need to spend time snapping each one into place, but would like the file to do this.
With that, is anyone able to provide me with correct code that would have the file behave as I intend for it to, or does anyone have a SKILL file that provides these same features and works as I intend it to?
Thanks.
  • DE202408202727
    DE202408202727 over 11 years ago
    The Skill is hard coded with "V2.2" so you must be loading the older version somehow?
  • SMyersPCB
    Dave you were right. I had the original file in the folder and I had renamed it "old_RotateSilkAssyRD.il" though I'm not sure if me physically removing the file or fully exiting the program and reentering was the trick, but I'm happy to show that the update did the trick.
    Follow up question, where did you get v2.2? I'd certainly like to be on top should I run into this issue again or with any other SKILL files I have.
    Thanks for the updated file, this will certainly be very handy.
  • DE202408202727
    I'm glad it's working for you now.
    It's my own update. I'm sure had posted it here previously.
  • Junior0304
    Junior0304 over 11 years ago
    thanks, very useful..
  • mareeswaran
    mareeswaran over 8 years ago in reply to DE202408202727
    Hello Dave,
    good day
    i have use V2.2 skill file .
    in this skill file text come to the part origin but couldn't rotate.
