  3. RotateSilkAssyRD.il does not "Center Assembly RDs at Part...
  • Replies 11
  • Subscribers 166
  • Views 8487
RotateSilkAssyRD.il does not "Center Assembly RDs at Part Origin"
SMyersPCB
SMyersPCB over 11 years ago
I am using the RotateSilkAssyRD.il SKILL file in which I use it to rotate all of my ref des for my Assembly. However, it doesn't snap the text to the symbol origin that its associated to resulting in me having to use the "Snap pick to..." command and snapping it to the Symbol Origin. When I run the file and check the box for "Center Assembly RDs at Part Origin," it will take all the text for that particular layer and throw it down and to the left. If I run it with the command off, it will leave the text as is and rotate it as I've selected, but it would be nice to have the feature corrected so it snaps to the center so save me time from clean up.
Attached is the SKILL file as I use it today and several screen shots.
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/RotateSilkAssyRD.il
How the file looks before I run the SKILL file, various text in various directions.
How it looks if I run with the option checked, the text is rotated, but its thrown way off and not snapped to the center.
How it looks with the option checked off, the text is correct and its close to the component. I just need to spend time snapping each one into place, but would like the file to do this.
With that, is anyone able to provide me with correct code that would have the file behave as I intend for it to, or does anyone have a SKILL file that provides these same features and works as I intend it to?
Thanks.
  • Soundman99
    Soundman99 over 11 years ago
    Very interesting.  I've been looking at similar skill scripts for us to use.  I actually put it aside for a few months now (other priorities taking over).  We like to be able to see the silk after assembly, for troubleshooting and debug purposes.
    This is from OrCAD, not sure if it works with the Allegro back-end tool or not, but check out this tool from FlowCAD:
    http://orcadmarketplace.com/ProductDetails/tabid/93/ProductID/17/Default.aspx
  • DE202408202727
    DE202408202727 over 11 years ago
    Attached is a more recent update. Although I am not sure that it will help.
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/7217.RotateSilkAssyRD.2.2.zip
  • SMyersPCB
    Thanks Dave, unfortauntely I faced the same outcome, just in a different direction. Attached is a screen shot, this time it moved the text in another direction. Also, the tool showed v2.1 in the title bar.
  • DE202408202727
    16.6?
  • SMyersPCB
    16.6 w/Hotfix #57.
