  3. Select Multiple pin
  • Views 16430
Select Multiple pin
Soundar1984
Soundar1984 over 11 years ago
hi,
how to select multiple pin.actually now im using axlSingleSelectPoint() and axlAddSelectPoint(). now i need to select above 50 pins continuously but not exact.is there any option like for select multiple pin in axl command.
  • DE202408202727
    DE202408202727 over 11 years ago
    It's unclear exactly what you want but try using the axlSelect command.
  • Soundar1984
    Hi Dave,
    actually i want to select multiple pins and vias randomly to get their dbid.
  • DE202408202727
    Use axlSelect and right click for temp group.
  • Soundar1984
    Hi Dave, Its working fine now..thanks a lot.. and I need a clarifications 1) if I select a same pin on different layers, will the dbid of the pin be same ? 2)how to select multiple items in a listbox(I have binded subclasses in listbox)? thanks
  • DE202408202727
    1) The pin dbid is not dependent on the pad layer that you select it from. However, dbids are dynamic so you won't see the same value.
    2) Add a multiselect option to your form list.
